Author Topic: Using the repository in Delphi  (Read 7004 times)
ufechner
  • I love YaBB 1 Gold!
« on: July 18, 2005, 06:25:41 pm »
I imported the type library with delphi and I am working fine with the EAProject component.
Now I try to use the repository component and have the following problem:
procedure TfrmMain.Button1Click(Sender: TObject);
var
 oElement: IDualElement;
 sTmp,sGUID: string;
 boResult: boolean;
 iCount: integer;
begin
 boResult:=self.EARepository.OpenFile(edtInputFile.Text);
 if boResult then begin
   iCount:=self.EARepository.Models.Count;
   self.foMyUserIO.outLog('ModelCount: '+inttostr(iCount), ltMsg);
   sGUID:='EAID_6AB8AFBB_2217_4f0f_979D_59200D08976D';
   oElement:=EARepository.GetElementByGuid(sGUID);
   //oElement:=EARepository.GetElementByGuid(self.edtElementID.Text);
   if oElement<>nil then begin
     sTmp:=oElement.Name;
   end;
 end;
end;
If I execute this code, oElement is always NIL.
(The GUID exists, and it is a class element.)
Any idea?
Reagards:
Uwe Fechner
Re: Using the repository in Delphi
« Reply #1 on: July 19, 2005, 03:22:57 pm »
Just guessing here, but it looks like you've got your guid from an xmi export.  It won't actually be in that form in the Repository.
Try '{6AB8AFBB_2217_4f0f_979D_59200D08976D}' instead.
Simon
ufechner
« Reply #2 on: July 22, 2005, 05:26:01 am »
your hint did help, but your suggestion was still wrong.
Wrong:  '{6AB8AFBB_2217_4f0f_979D_59200D08976D}'
Right:    '{6AB8AFBB-2217-4f0f-979D-59200D08976D}'
Why do you use different ways to represent GUID's in the project and in the repository interface?
PLEASE add a hint regarding this issue to the online help (documentation of methods of the automation interface).
Regards:
Uwe Fechner
« Last Edit: July 22, 2005, 05:26:40 am by ufechner »
« Reply #3 on: July 24, 2005, 03:40:26 pm »
Sorry, I missed that difference.
My guess is that the difference is because the DTD for XMI doesn't allow it in the form it's saved in the database.
Simon
