Author Topic: Skipping steps in a use case alternate flow  (Read 16867 times)
inad
« on: February 15, 2012, 02:30:38 am »
Just trying to gather thoughts and opinions on how folks handle this.
So I have this alternate path in a use case of mine. It happens to be identical to the main flow except that a couple of steps are skipped. I would be inclined to write a simple alternate path such as:
At {Extension Point} if {condition}
1.- The flow of events proceeds exactly as in the basic path except that steps x and y are skipped.
Is this common practice. Are there alternative/better ways of handling this ?
Re: Skipping steps in a use case alternate flow
« Reply #1 on: February 15, 2012, 08:40:41 pm »
I think that if the desciption can be understood it is okay. In that case, well yes. I as a reader can understand what you mean. You should add a step 2. "The use case ends" to make that clear.
Robert Sheridan
« Reply #2 on: February 23, 2012, 03:06:28 am »
Thanks, before I started using stuctured scenarios I wrote alternates with 'omit steps x and y' and was wondering how to do it in structured scenarios.  It wont generate a activity diagram automatically but that is a small price to pay.
RoyC
  • Read The Help!
« Reply #3 on: February 23, 2012, 09:30:50 am »
(Extrapolating from the letters of your steps) wouldn't you make your alternative path take effect at step w of the main flow and say "if {condition} then step out and rejoin Main at step z"?
Best Regards, Roy
Doug Blake
« Reply #4 on: February 23, 2012, 08:18:47 pm »
I would say that in general, we have a lazy streak (not a criticism) so its easy to say 'same x but leave out y'.
I would copy the original and delete the steps so I have a complete standalone description of the scenario with no references to other scenarios.
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
Robert Sheridan
« Reply #5 on: March 01, 2012, 12:08:09 am »
I have been on projects where all the steps from the Normal were replicated and in my view it creates 2 challenges:
1. It makes the use case less concise to read (though also less ambiguous) and I have found that large docs => poorer reviews
2. If the main flow changes you have to replicate the changes to all the other flows (I know, I am basically lazy)
« Reply #6 on: March 01, 2012, 12:36:28 pm »
It's more than it just being a "lazy streak".  Engineers are inherently lazy people (why do I need to do this repetitive thing?).
Its also the tension between declarative and prescriptive specifications.
"Same as X but leave out Y" is a declarative form.
I'm all for declarative forms whenever possible, because they embody a greater truth.  The problem is how to generate the implementation (which currently needs to be prescriptive) from the declarative form.
