Author Topic: merge interaction  (Read 12503 times)
safian
merge interaction
« on: May 11, 2012, 01:15:33 am »
im as a new user, i like to knoe how can i merge the interaction from other guys interaction. please help me..
Makulik
Re: merge interaction
« Reply #1 on: May 11, 2012, 01:43:17 am »
Do you mean using EA projects with a team? Then these sections in the Online Help might point you in the right directions:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/projects_and_teams/configuration_management.html
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/projects_and_teams/versioncontrol.html
There are several ways to collaborate on projects, what's the best for you might depend on team and project size.
Günther
Makulik
« Reply #2 on: May 11, 2012, 06:21:01 pm »
Received via PM:
can i know how i can merge the interaction from another EA file..?
You should continue the discussion on the user forum, that others can participate and benefit from the information.
So if I understand you right, there are other UML projects from your colleagues, containing parts you want to reuse in your project. Basically that is a poor approach, you should consider setting up ONE project that is used in a shared environment. These were the pointers for I gave you.
It's possible though, that you can use stuff from other EA projects, by using XMI exports and importing these to your project and use them there.
Günther
