Author Topic: Removing unwanted transforms from repository  (Read 11831 times)
AlanH
« on: March 25, 2008, 10:43:35 am »
have been using EA Transforms to generate physical data models for ORACLE DB... have a number of tramsform versions and want to remove unwanted ones...
Also I cannot import a Transform to production EA DB that I modified in a DEV EAP... would like to replace the existing version, but cannot delete it.... can anyone help me here?
Al
Re: Removing unwanted transforms from repository
« Reply #1 on: March 25, 2008, 12:00:38 pm »
1. Deleting each template in the transform editor.  Note that the dropdown for transformations won't remove entries until you close and re-open the editor.  If this is too laborious you could use a direct sql call (with appropriate backups...)
2. Have a look at Tools | Import/Export Reference Data.
« Last Edit: March 25, 2008, 04:13:26 pm by simonm »
