Author Topic: visio 2007 support  (Read 4712 times)
gkathan
  • ...de-accelerat e...
visio 2007 support
« on: July 15, 2008, 04:54:03 pm »
hej,
i just tried to import a visio file with the new importer tool => unfortunately it does not support visio2007
* when do you plan to support it ?
* it also did not work after i saved the vsd file as visio 2002 format
greetings from vienna,
gerold
Aaron B
Re: visio 2007 support
« Reply #1 on: July 16, 2008, 09:20:29 am »
Hello Gerald,
When using the Visio Importer Add-In, it does not matter what the file format is.  The Add-In does not directly read the file.  Instead the file is opened in Visio, and the Add-In gets the information through Visio's automation interface.  So the dependency is on the installed version of Visio, not the saved file format.
FYI: The version requirement was largely enforced due to a dependency on the XMI plugin for Visio which we use to extract vital information from UML diagrams in Visio.  Microsoft only released this plugin for Visio 2002 and 2003.
Please send an email to [email protected] on this subject and we can try to assist you further.  If you are able to attach some example diagrams that you are trying to import, this may also be of some help.
