Author Topic: Add connector to diagram  (Read 7718 times)
Harley
« on: November 10, 2005, 08:19:09 pm »
Hey there
I woulda thought that this would be pretty simple...
How can I add a connector to a diagram? I've tried using DiagramLinks.AddNew to no avail.
Harley
Re: Add connector to diagram
« Reply #1 on: November 10, 2005, 08:48:34 pm »
You don't add connectors to a diagram, you add them between elements:
Dim con as EA.Connector
Set con = element1.Connectors.AddNew("Name","Dependency")
con.SupplierID = element2.ElementID
con.Update
Then if both element1 and element2 are on the diagram, you can refresh the diagram and the connector should appear.
« Last Edit: November 10, 2005, 08:49:28 pm by KP »
Harley
« Reply #2 on: November 11, 2005, 09:27:02 pm »
KP - thanks for the reply.
I have kinda got it working - not sure if this is something I'm doing wrong. If I create a connector using:
Target.Connectors.AddNew("", "Generalization") as Connector;
it works as expected. However, if I use:
Target.Connectors.AddNew("", "Realization") as Connector;
I don't get anything on the diagram. However, the link does appear in the properties of the elements I am linking.
Harley
« Reply #3 on: November 14, 2005, 07:25:51 pm »
EA has a spelling mistake in its internals... Try spelling it "Realisation"  :-[  :-X  :-/
mikewhit
  • Accessing ....
« Reply #4 on: November 15, 2005, 04:40:56 am »
Excuse me, that's how you spell "Realisation" ... unless you're American !
Harley
« Reply #5 on: November 15, 2005, 06:33:50 am »
Indeed it is. Maybe the issue is simply a documentation typo then:
" When creating a new connector you must assign it a valid type. These are:
· Aggregation
· Association
· Collaboration
· Dependency
· Generalization
· Instantiation
· Nesting
· NoteLink
· Realization
· Sequence
· StateFlow
· UseCase"
Harley
« Reply #6 on: November 20, 2005, 01:26:27 pm »
I agree.  Unfortunately I believe the UML spec was written in American English.
