Author Topic: diagram legend empty after save and re-open  (Read 6385 times)
ps_ea
« on: November 13, 2008, 11:25:24 pm »
Hi all!
I create an UML diagram legend via context menu: Create element or connector/Common Elements/Diagram Legend. Then I can fill the legend via properties window.
So far, everything is fine.
But when I save the diagram, close and re-open it, the legend is still there but it is empty. All my entries are gone.
Is this a bug or am I doing something wrong?
I use EA Corporate Edition 6.5.802.
Brgds, Peter
RoyC
  • Read The Help!
Re: diagram legend empty after save and re-open
« Reply #1 on: November 14, 2008, 09:43:13 am »
This might be a silly question, but did you save the legend in the Properties dialog before you exited the dialog and closed the diagram? I don't have release 6.5 to check; I'd hope that the dialog wouldn't let you exit without saving.
Best Regards, Roy
mrf
« Reply #2 on: November 14, 2008, 11:48:00 am »
Hi Peter,
I remember this issue poking its head up a while back. From what I remember it was related to a problem with the MS Jet Driver (of all things) when performing certain queries in certain conditions.
Can you please configure EA to use the Jet 4 driver (see http://www.sparxsystems.com/uml_tool_guide/uml_modeling_tool_features/generalsettings.html) and see if that works.
Best Regards,
Michael
ps_ea
« Reply #3 on: December 03, 2008, 08:07:10 pm »
You are warned if you have unsaved changes. And if you don't save, then the legend doesn't show your entries at all. So that's not the problem...
PS: My late reply is because I was not notified about your reply. I think I checked the "I want to be notified..."
ps_ea
« Reply #4 on: December 03, 2008, 08:16:15 pm »
Hey, that's it! I checked the "Use JET 4.0", restarted EA, re-opened the project, and there appeared my legend  :)
Thanks a lot mrf!
Bad luck I did not come back to the forum earlier to see if anybody replied.
ps_ea
« Reply #5 on: December 03, 2008, 08:23:34 pm »
Just a test to see if I get a notification this time.
Peter
« Reply #6 on: December 04, 2008, 12:19:06 am »
Here's a reply then. Did you get the notification?
ps_ea
« Reply #7 on: December 04, 2008, 12:37:27 am »
Yes, got one. Thanks! Something must have been wrong last time.
