Author Topic: Default database type  (Read 4040 times)
srivaths
« on: October 28, 2009, 01:32:35 am »
I am a relatively new user of EA and only just stepping into data modeling.  In explaining how to create columns for a table (http://www.sparxsystems.com/uml_tool_guide/data_modeling/createcolumns.html) the doc says that you can set a default database type to obviate having to set it for each table you add.  The docs refer you to http://www.sparxsystems.com/uml_tool_guide/data_modeling/o411.html, however there is no information there on how to set the default database type.
Can you help?
Sri
RoyC
  • Read The Help!
« Last Edit: October 28, 2009, 09:49:34 am by RoyC »
Best Regards, Roy
Re: Default database type
« Reply #2 on: October 28, 2009, 10:07:14 am »
That appears to be a rogue link. It should point to:
http://www.sparxsystems.com/uml_tool_guide/uml_modeling_tool_features/codetoolbar.html
or
http://www.sparxsystems.com/uml_tool_guide/code_engineering/cgo_editor.html
Apologies.
Hi Roy,
Since there's only one link and two possible targets, have you decided which one it should point to?   ;)
(yes, " 'es avin' a laff!")  ;D
RoyC
  • Read The Help!
« Reply #3 on: October 28, 2009, 10:42:19 am »
Eenie, meenie, minie....
Code Toolbar. It's easier to access. Thanks for the wedgie....
Best Regards, Roy
