Author Topic: Locked objects  (Read 7195 times)
piotrek84
Locked objects
« on: January 15, 2010, 09:03:48 pm »
Dear All,
I'm creating a SysML Internal Block diagram; I've created all the required parts with ports on them. In most cases i was able to create links between ports but some (valid!) connections can't be created because: "Both the Start and the End objects are locked. You cannot create a link at this time". I've checked 'My Locks' there are none.
Did anyone had a similar problem?
Regards
Re: Locked objects
« Reply #1 on: January 15, 2010, 09:06:32 pm »
Maybe that is the problem, that you haven't locked the elements.
Which type of security setup are you using? The "require lock to edit" mode?
piotrek84
Re: Locked objects
« Reply #2 on: January 15, 2010, 09:11:00 pm »
I'm using a Corporate version and I'm not the admin so I can't really check it... But the thing is that for some ports I can create connections for some I can't - there doesn't seem to be a logical pattern. All the objects are in the same package so they're all checked-out.
Re: Locked objects
« Reply #3 on: January 15, 2010, 09:22:38 pm »
That's strange, and you can edit both end objects for which you can't create a connection?
piotrek84
Re: Locked objects
« Reply #4 on: January 15, 2010, 09:28:08 pm »
Yes. Let's say I have 3 ports: OUT1, OUT2 and IN1. I can connect OUT1 with OUT2, I can connect OUT1 with IN1, but I can't connect OUT2 with IN1...
Peter
piotrek84
Re: Locked objects
« Reply #5 on: January 15, 2010, 09:33:03 pm »
I've deleted the part and created it again - now everything is fine... Maybe it was some kind of DB error...
Peter
Re: Locked objects
« Reply #6 on: January 15, 2010, 09:38:41 pm »
Or it could be that the "locked" status got out of synch with the VC.
There is an option to synchronise those, that might have helped too.
piotrek84
Re: Locked objects
« Reply #7 on: January 15, 2010, 10:17:00 pm »
Thanks for help.
Peter
Re: Locked objects
« Reply #8 on: January 18, 2010, 10:26:43 am »
The problem is with port instances and it has been fixed for the next release.
Re: Locked objects
« Reply #9 on: January 18, 2010, 07:15:31 pm »
still no hint when that is going to be released?
... pretty please... :D
Re: Locked objects
« Reply #10 on: January 18, 2010, 07:46:36 pm »
You should check out the Dilbert 2010 calendar entry for 10th January.  Where the secretary books a pre-meeting for the day after the meeting.
The last panel shows the secretary thinking: "There's a fine line between evil and under-paid."
Re: Locked objects
« Reply #11 on: January 18, 2010, 08:19:37 pm »
 ;D
