Author Topic: AssociationClass missing from QuickLinker  (Read 3755 times)
« on: May 10, 2010, 12:16:13 pm »
In the list of available Element Types for the QuickLinker (b:856), Association Class is missing...
Believe it or not, there ARE relationships that exist ONLY between AssociationClasses and  other elements.  But you can't specify them in QuickLinker.  See: New Edge type: AssociationEnd
What makes it stranger is that n-ary Association IS on the list and behaves correctly.
I believe it would be acceptable if those relationships defined for n_ary Associations would also apply to AssociationClasses.  After all, an AssociationClass is merely a 2-ary Association.  See: N-Ary Associations and Association Class
Reported,
If you want to vote for a fix for this, submit a Registered Bug Report or Bug Report
with the same name, leaving a note here to say you've done it
 - so we users have an indication of the level of support.
« Last Edit: May 10, 2010, 12:31:31 pm by PaoloFCantoni »
SomersetGraham
Re: AssociationClass missing from QuickLinker
« Reply #1 on: May 10, 2010, 05:26:16 pm »
Bug report sent
Using V12
