Author Topic: 855: Locking: missing new group  (Read 5537 times)
Aljaz
« on: April 20, 2010, 03:56:38 pm »
Hi!
I switched to the new version and did this:
- opened a new group
- set permissions for this new group
- assigned a user to the new group
- went to a model and tried to lock it to the new group
- did not see the newly created group among other existing groups.
Using accdb as database.
Re: 855: Locking: missing new group
« Reply #1 on: April 21, 2010, 02:17:27 am »
[size=18]...[/size]
Hi Aljaz,
is that as a Server or as native .EAP file (use of accdb DB)?
Aljaz
« Reply #2 on: April 21, 2010, 10:01:06 pm »
Hi!
I don't understand what you mean. Instead of using native eap file I chose to migrate it to an access database, which is also a file. It's not run on msde or something. Just plain old (well, new) access database file.
And I'm kind of confused as to behaviour I already described. It's not straight forward to reproduce and I haven't found a pattern when it occurs and when not. What I mean is,
- first I thought the group list from the drop down list under locking option is somewhat limited and because there is no slider some groups probably fall out of the listing,
- then I again created a group with a somewhat intuitive name "A" and it appeared in the list. I didn't check the number of groups though shown in the list.
So I'm really confused about it. I managed to create a group and get it listed but am not still sure of why in previous attempts it didn't appear.
« Reply #3 on: April 22, 2010, 02:33:09 am »
You do realize that the native eap file is just a plain old ms access file with a renamed extension? :-/
So all you needed to do to migrate to an access database was... well nothing 8-)
Aljaz
« Reply #4 on: April 22, 2010, 03:31:10 am »
I am very well aware of that. It's just that I decided to do a single corporate project file and since it would be to complicated to explain our IT how to do either oracle or svn I chose the most obvious way - the newer file format that shouldn't be size limited as the older ones were.
On the other hand I also believe that you have to move to newer things as they appear. MDB is slowly on its way out.
Aljaz
« Reply #5 on: May 13, 2010, 06:17:00 pm »
Just an update:
I switched back to eap from accdb because it's not stable enough for production use. Things dissapeared after compacting/repairing database, auditing didn't work, etc.
« Last Edit: May 13, 2010, 06:17:24 pm by aljaz »
