Author Topic: error message in html report generation  (Read 3972 times)
PolgarJudit
« on: May 19, 2010, 07:06:21 pm »
Error message=Error writing file or directory. Generation did not complete successfully.
What should I do to fix this problem?
« Last Edit: May 19, 2010, 07:09:07 pm by PolgarJudit »
SomersetGraham
Re: error message in html report generation
« Reply #1 on: May 19, 2010, 07:17:34 pm »
Ensure that the destination directory exists and is writable
Using V12
PolgarJudit
« Reply #2 on: May 19, 2010, 10:01:57 pm »
Thank You for your answer. I made full cheking. Directory exists and writable. On top of all, if I start generation in rtf form to the same destination directory, the generation is successfully. The mentioned error message appears only in html case.
Frank Horn
« Reply #3 on: May 19, 2010, 11:04:16 pm »
Sometimes this seems to happen when you generate an html report the second time with the same target directory. I could work around it by deleting the old report first.
