Author Topic: Textline in Notes disapear  (Read 4465 times)
jojo74
« on: May 13, 2010, 05:30:45 pm »
We have reproduce this issue:
When using accented Czech characters - textlines in Notes of graphic elements desapears. Can you please advice how to fix this?
Thanx
Environment:
WIN7 EN; EA 8.0 - Unicode
Steps to reproduce:
1) insert cursor into Notes array of some element
(pict step 1)
2) write "ý" character (text line disapear)
(pict step 2)
3) click somewhere else
4) click on into the Notes array again (text line apears)
(pict step 4)
pict step 1:
pict step 2:
pict step 4:
« Last Edit: May 13, 2010, 05:37:48 pm by jojo74 »
Tomket_66
Re: Textline in Notes disapear
« Reply #1 on: June 07, 2010, 06:45:21 pm »
I have the same problem in the same environment.
« Reply #2 on: June 07, 2010, 07:13:23 pm »
Has this been reported to Sparx?
Please use the Report a Bug link on the bottom of your page to officially report something to Sparx.
jojo74
« Reply #3 on: June 09, 2010, 12:04:12 am »
Well I have reported this issue as a bug. I will let you know the answere  :)
Jana
« Last Edit: June 09, 2010, 12:04:46 am by jojo74 »
jojo74
« Reply #4 on: June 09, 2010, 11:37:03 pm »
This post has been added as an issue number 10055813.
mrf
« Reply #5 on: June 10, 2010, 08:49:43 am »
What repository type are you saving to there? If you're saving to EAP file, make sure you are using a Jet4 repository and driver, the Jet 3 driver (and the corresponding Jet 3 EABase.eap) do not support Unicode, which means that characters outside of the ANSI range will be lost/converted.
If you are using the default EA setup (Jet3 driver and Jet3 EABase.eap) then:
1. Configure EA to use the Jet 4 driver (Tools | Options)
2. Download the Jet 4 EABase.eap from the Resources section of the website
If you are using a DBMS repository, then ensure the Collation settings are configured for your locale. If everything is configured fine and still causing errors, then please pursue us through the support channels.
Best Regards,
Michael
