Author Topic: Visio import (with MDG Tech plugin) crashes EA  (Read 7363 times)
robert.staflin
« on: August 26, 2010, 09:57:15 pm »
I've tried with EA 8.0 855 and 862, and EA consistently crashes when I try to import Visio documents using "Add-in|Microsoft Visio|Import Visio Documents..." from a drop down menu.
It seems that it always fails when trying to import the connectors, no matter which size and complexity of Visio document I try (Visio 10). Any ideas, please? Perhaps the MDG plugin is too old for Visio 10?
/Robert Staflin (Windows error info follows)
Problemsignatur:
  Problemhändelsens namn:      APPCRASH
  Programnamn:      EA.exe
  Programversion:      8.0.0.862
  Programtidsstämpel:      4c6b62e4
  Namn på felmodul:      ntdll.dll
  Modulens version:      6.1.7600.16559
  Tidsstämpel för felmodul:      4ba9b29c
  Undantagskod:      c0150010
  Undantagsförskjutning:      0008454b
  OS-version:      6.1.7600.2.0.0.256.1
  Språkvariant-ID:      1053
  Ytterligare information 1:      0a9e
  Ytterligare information 2:      0a9e372d3b4ad19135b953a78882e789
  Ytterligare information 3:      0a9e
  Ytterligare information 4:      0a9e372d3b4ad19135b953a78882e789
« Last Edit: August 26, 2010, 09:57:45 pm by robert.staflin »
Re: Visio import (with MDG Tech plugin) crashes EA
« Reply #1 on: August 26, 2010, 10:19:45 pm »
I think they only support up to visio 2007. See http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1251264266/0#0
robert.staflin
« Reply #2 on: August 27, 2010, 12:57:39 am »
Didn't help with an older Visio vile though - same problem... :(
Sunshine
  • Its the results that count
« Reply #3 on: August 31, 2010, 08:03:46 pm »
I had a similar problem importing Visio 2003 diagrams a while back (3yrs+). I recall the visio MDG importer didn't seem to work properly with SQL server repository but did with and EAP file. The work around was to import it into and EAP file then export the result as XMI and then import into a SQL Server repository.
What repository database are you using?
Happy to help
