Author Topic: Size of Port in Component  (Read 3951 times)
Uffe
« on: February 03, 2011, 02:49:57 am »
Hi!
I'm working on a rather large and involved MDG Technology, and I'm bumping into a problem with Port sizes.
I create a Component (A) with a stereotype defined in one of my profiles, and then drop that Component onto a different Component (B), the resulting Port ends up huge - and I can't resize it.
I get the same result if I create the Port first and set its Property Type.
If I then change the Port's Property Type to a stereotype-less Component (C), the Port shrinks down to the regular size.
Anyone recognize this? Is there anything I can do to fix it?
Cheers,
/Uffe
Re: Size of Port in Component
« Reply #1 on: February 03, 2011, 03:47:08 am »
I had the same issue but can't recall how I solved it. Somehow I did ... probably EAUI. You need to poke around randomly or hope for better advice from others.
