Author Topic: Datatype mapping  (Read 3711 times)
Peter Parslow
Datatype mapping
« on: January 26, 2010, 10:25:03 pm »
Searching the forum doesn't return anything for 'datatype map', so I'll start a new topic.
I have created a database product "TC211" containing some of the data types used by ISO TC211. I have created a datatype map to map these to Oracle. The tool for doing that is rather clumsy, but I believe I've got there.
But it doesn't work as I would expect, so CharacterString turns to VARCHAR(36), regardless of the length I specify in the map (and it would be even better to be able to specify it in the logical model); Boolean, which I've specified has a max length of 1 comes out as NUMBER(22).
Any suggestions?
dannodj
Re: Datatype mapping
« Reply #1 on: January 27, 2010, 03:12:41 am »
Hi Peter,
i am doing datatype conversions from logical model to xml schema and have used the transformation templates as follows.
%if attType=="Date"%
  type="xs:date"
%elseIf attType=="Title"%
  type="xs:string"
%elseIf attType=="indicator"%
  type="xs:boolean"
%elseIf attType=="Description"%
  type="xs:string"
%elseIf attType=="Time"%
  type="xs:time"
%else%
  type="xs:string"
%endIf%
It may be that the transformation you are doing has an inbuilt conversion?  I hope this helps a bit.
Dan
Peter Parslow
« Reply #2 on: May 12, 2011, 01:04:29 am »
Re-raised as http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1305025781
I was referring to the Datatype Map which is used by EA's "Reset DBMS"; the response last year seems to relate to scripting, which could be an option I guess.
