Author Topic: Possible Solution for the 904 & 905 crash issu  (Read 5405 times)
intrepid
« on: May 21, 2011, 04:42:58 pm »
I think I may have found a solution to the crash issue people are having with the new release.
To fix the problem try the following:
NB!!! These steps were tested on Windows XP only
1. Uninstall the application.
2. Delete the “Sparx Systems” directory from the Program Files folder e.g. c:\Program Files\Sparx Systems
3. Delete the “Sparx Systems” directory for the current user
e.g. on Windows XP delete C:\Documents and Settings\joeblogs\Application Data\Sparx Systems
and on Windows 7 delete c:\users\joeblogs\Appdata\Roaming\SparxSystems
4. Delete the following key in the registry: HKEY_CURRENT_USER\Software\Sparx Systems
5. Restart the workstation
6. Install the new Version 9 software
7. Launch the program
8. Enter your license key (if using a fixed license)
9. You're good to go (if you're lucky)
Hope that helps!
« Last Edit: May 21, 2011, 06:51:40 pm by intrepid »
Stefan Bolleininger
Re: Possible Solution for the 904 & 905 crash issu
« Reply #1 on: May 21, 2011, 06:17:11 pm »
Hi there,
thanks for you suggestion but unfortunatley i have to say i doesn't work ( at least for me)
However on Win7 i had to look in C:/users/johndoe/Appdata/Roaming/SparxSystems
Build was 905
maybe the next idea works!
Good luck!
intrepid
« Reply #2 on: May 21, 2011, 06:38:45 pm »
Hi there,
Build was 905
Good luck!
You're right about the location of the user directory being different for Win 7. I'll edit the steps to include that.
Sorry it didn't work for you :-(
maxmudit
« Reply #3 on: May 21, 2011, 09:40:43 pm »
Hope that helps!
I tried these steps on Win 7 64 bit with only change that I went ahead and deleted all registry entries for "Sparx Systems". After that the 9.904 EA ran fine after a fresh install. I did not even restart the machine after clearing the registry. Thanks to intrepid..
Stefan Bolleininger
« Reply #4 on: May 21, 2011, 10:00:06 pm »
Hi there,
is it possible to get the 904 build from somewhere?
intrepid
« Reply #5 on: May 21, 2011, 10:22:27 pm »
Hi there,
Hi #Sethor
See my PM to you...
Stefan Bolleininger
« Reply #6 on: May 22, 2011, 12:39:30 am »
now my next step during the odysee:
Installed the ea9 9.04 like intrepid suggested -> doenst work
Installed EA9 905-TRIAL TRIAL works
Want to fill the license-key into the TRIAL ( Help - Register and manage license-Keys)
and.... CRASH  :'(
I new IDEA - i'm going out for running now.... And wait for the next build!
Offtopic but nice and funny: I have a magazine from this year 2011 with focus on Software quality - There is a nice article about "Failure-free very usable Software is possible" Chapter Specifications and Tests and think what company has its advertisement under it? You are right - Sparx Systems Enterprise Architect :)
Maybe someone has the next idea?
