Author Topic: Memory leakage in 906?  (Read 4449 times)
MagnusH
« on: May 27, 2011, 04:51:24 pm »
When I start build 906 (not even loading a project) the task mgr reveals that memory usage is increasing over time (each fifth second 4k is taken!). Look att column "Mem usage" and "VM size".
Using XP and a license file on a file server.
Someone else seeing this?
Magnus
Re: Memory leakage in 906?
« Reply #1 on: May 27, 2011, 05:27:16 pm »
Nope,
Memory usage seems stable around 320.000 K on my machine (also WinXP, but with a local license)
It increases if I open more diagrams, but it decreases when closing diagrams.
I've had EA open the whole night, so if it would be leaking memory it should have become a problem by now.
SomersetGraham
« Reply #2 on: May 27, 2011, 05:39:36 pm »
No problems here either
Using V12
« Reply #3 on: May 27, 2011, 09:19:26 pm »
I've processed over 6000 diagrams (admittedly closing each one after processing) overnight (about 14 hours) without issue...
So you'd expect if there was a (generic) memory leak it would show up there.
Next time I do it, I'll check the memory values.
MagnusH
« Reply #4 on: May 27, 2011, 09:26:40 pm »
Hi
I noticed that when I'm connected at the corporate network directly I have no problem at all. This morning I worked at home with a VPN connection and then I had the problem...
// Magnus
