Author Topic: Configuration SVN : what do i do wrong?  (Read 4393 times)
NicoDonckels
« on: May 17, 2011, 07:20:08 pm »
After setting up With TortoiseSVN the directory. I tried to setup the version control settings. For SVN.exe i used Collab.net and SlikSVN. When clicking on Save Sparx EA is Hanging?? What do i do Wrong ? :(
Re: Configuration SVN : what do i do wrong?
« Reply #1 on: May 18, 2011, 01:53:58 am »
Is the svn server up?
« Reply #2 on: May 18, 2011, 04:38:40 pm »
Nico,
A few suggestions:
- make sure you use the correct versions of the SVN executables. EA is pretty picky those things. (a forum search for SVN should yield some useful results)
- make sure you have the appropriate rights on the SVN repository
- start from an empty svn repository. When connecting to version control EA launches some sort of getALLthingsInRepository query that can take some time when you have a lot in there. I've had that issue with TFS in the past, same symptoms, EA seemed to hang while it was getting the info from TFS.
- last suggestion, try the same thing with version 9. IIRC they've fixed a thing or two regarding version control stuff.
Ondrej Medek
« Reply #3 on: June 10, 2011, 05:31:29 pm »
the "Working copy path" has to be a directory under SVN control (i.e. added and commited to the SVN).
Thomas_Arnbjerg
« Reply #4 on: June 10, 2011, 07:18:46 pm »
Have you persisted your credentials (maybe it's hanging in the authentication step)? We are using SVN without problems
