Author Topic: why generate code type is java, I can't change.  (Read 4358 times)
calmman
« on: October 31, 2011, 10:29:11 pm »
hello
I download ea9.1 trial version. and create a defualt class model.
there are some class in the model fold. like class1, class2, class3.
follow the step, I want generate c++ souce code.
1. tools->options->source code engineering->set c++ is default code.
2. disable other language, eg, java, C#
3. select class model node in project brower, and click right bottom call the context menu. select source code engineering->generate source code.
and I found the result of operation is java source not c++ source.
if I do generate operation on single class, like class1, the result is .h and .cpp
please help, thanks a lot!
« Last Edit: October 31, 2011, 10:30:23 pm by calmman »
Re: why generate code type is java, I can't change
« Reply #1 on: November 02, 2011, 09:06:13 am »
The option at "Tools>Options>Source Code Engineering>Default Language for Code Generation" will set the language for all new classes that you create. To change the language defined for existing classes, in the Project Browser right-click the package that owns the classes and use "Code Engineering>Reset Options for this Package" (or if it's just one class, open its Properties dialog and change the Language setting on there).
« Last Edit: November 02, 2011, 09:17:11 am by KP »
calmman
« Reply #2 on: November 02, 2011, 12:19:24 pm »
thank you very much. I get it! :D
