Author Topic: Generalise & Realise  (Read 3208 times)
wombat
« on: May 07, 2004, 04:27:23 pm »
Hi All,
I'm having a bit of trouble with the overriding feature in EA.  Basically, if i started out with "interface" A and "class" B where class B implements the A interface.  Now currently if A has any opertation defined, when i create the 'realise' relationship, EA would prompt whether i want to override the defined method - that's ok.  Now if i then add a new operation to A - what do i have to do to make that new operation appears in B ???
Thanks for your patient
Andreas_G
  • And that's the way the cookie crumbles.
Re: Generalise & Realise
« Reply #1 on: May 10, 2004, 12:19:38 am »
Hi wombat,
select class B in the diagramm, then chose "Override Implementation..." Command form the "Element" Menu.
hope, that helps
Andreas
bye
Andreas
Barry_Pearce
« Reply #2 on: June 24, 2004, 04:16:23 pm »
Or select calss B and hit ctrl-shift-O
