Author Topic: Import DB Schema disabled  (Read 4752 times)
AndyM
« on: April 10, 2006, 03:40:44 am »
I know this is probably elementary, I have just taken over EA from someone who left.
I wish to import a table schema from SQL Server, but when I go into
Project->DataBase Engineering
the option
Import DB Schema from ODBC
is grayed out.  I cannot see how to enable it.
I am running EA v6.0.781 Registered Professional Edition.
Bruno.Cossi
Re: Import DB Schema disabled
« Reply #1 on: April 10, 2006, 03:42:34 am »
first thing that comes to mind: do you have a project file open?
Bruno
AndyM
« Reply #2 on: April 10, 2006, 03:54:48 am »
Hi Bruno
I do have a project open and I have tried via the right click option in the Project Explorer window but the option is also grayed out in the context menu.
Is there any other advice you could offer?
Andy
AndyM
« Reply #3 on: April 10, 2006, 04:08:41 am »
I have created a blank project and can successfully import the table schema into that.  I still cannot import into the project file I  wish to.
Any further help would be appreciated.
AndyM
« Reply #4 on: April 10, 2006, 04:17:25 am »
OK, found it....
I was on a diagram page that was set to locked.  I moved to a page that was not locked. and then the option became available.
Hope this helps the next newbie.....
Cavan “Kevin” G. Watson
« Reply #5 on: April 12, 2006, 07:19:16 pm »
Cheers.... Now what. locked? and how you do it? Is it a way to stop co-workers from Dabbling in my creations.
Stay tough
Kevin
AndyM
« Reply #6 on: April 13, 2006, 01:25:56 am »
Its Diagram->Lock Diagram
Just prevents inadvertent slip-ups when navigating.  I don't believe that you can prevent anyone from unlocking the page.  If your co-workers do not need to edit the diagrams you might consider giving them the free view-only version of EA.
Regards
Andy
« Reply #7 on: April 17, 2006, 03:03:12 pm »
There are other locking mechanisms in EA.
If you enable security (corporate edition only) you can lock parts of the model for only a particular user or group of users to edit.  You can also set up permissions for a variety of things.
Then there is also version control support which locks packages unless you currently have them checked out.
