Author Topic: Linux - problem with XML export  (Read 13095 times)
zuber
« on: February 26, 2020, 08:33:20 pm »
I'm using Enterprise Architect 13 with wine 5.2 on Linux.
I installed everything according to guide: https://sparxsystems.com/enterprise_architect_user_guide/14.0/product_information/enterprise_architect_linux.html
I tried wine 32 and 64 bit modes.
Everything works fine except XML export - all XML exported files are broken.
The same Enterprise Architect 13 run on Windows works fine.
Anyone had similar issue and was able to fix it?
Re: Linux - problem with XML export
« Reply #1 on: February 26, 2020, 09:12:55 pm »
What do you mean by "broken"? In any case you should contact Sparx' support via mail.
zuber
« Reply #2 on: February 27, 2020, 12:41:29 am »
Yes, I contacted them and I'm waiting for response.
Broken means:
- XML export from EA running with Wine is different from the one running on real windows
- when exported and imported again - there are errors and drawing cannot be restored
- there are
 inserted in every line of XML file (I suppose encoded windows end-of-lines)
« Reply #3 on: February 27, 2020, 04:12:11 am »
Seriously looks like a bug. If it gets fixed (who knows) you will only get a fix for the latest EA version. Be prepared.
As a work around: send it through SED and fix it that way.
zuber
« Reply #4 on: February 27, 2020, 07:19:11 am »
Maybe problem is somewhere in Wine configuration? I use Ubuntu 18.04 and Wine 5.2 + xml packages from microsoft.
timoc
« Reply #5 on: February 28, 2020, 09:54:19 pm »
I use crossover at https://www.codeweavers.com/. If you are wiling to invest in a tool like EA and use Linux, crossover is well worth it. You can try a demo before investing. It is a managed wine environment, once set up allows you to export/backup your EA between distros, and across versions.
You may also have luck under Steam for Linux, which uses crossover technology under the hood, but i have not tried it.
zuber
« Reply #6 on: March 03, 2020, 05:56:06 pm »
Small update: Wine was updated to 5.3.
XML export still works NOK.
« Last Edit: March 04, 2020, 07:35:52 pm by zuber »
zuber
« Reply #7 on: March 05, 2020, 06:21:43 pm »
I tried also with Enterprise Architect 15 - the same problem.
