Author Topic: Automation of execution of add-in from command line  (Read 3162 times)
priombiswas89
« on: June 01, 2021, 08:44:09 pm »
I have developed an EA plugin which generates yaml from several types of UML diagram. Workflow of the add-in is depicted in below images:
Step 1: https://ibb.co/jzCpm10
Step 2:https://ibb.co/x8GJx4R
I want to automate this process. What I need to do is, while user opens a command prompt, he/she will enter
  • .eap file path
  • GUID
  • yaml file generation path
Then commands should open Enterprise architect with the project file specified, run the add-in on the diagram, and generate the yaml file to the specified path.
I am trying to use below code for the purpose. Am I on right track?
class Program
        static string File = "C:/Users/priom/Documents/Enterprise Architect/StateMachineExportTest.eap";//Path to.eap-File;
        static string GUID = "243F8FA4-D5B1-49e4-9E90-13D7A0E01ED6";//GUID of required package;
        static string Doc_Template = ".txt"; //Name of Document_Template
        static string FileName = "Output";//Name of generated File;
        static void Main(string[] args)
            EA.App EAClient = new EA.App();
            EA.Repository EA_Repo = new EA.Repository();
            //EA_Repo.LoadAddins();
            EA.Project EA_Proj = new EA.Project();
            EA_Repo.OpenFile(File);
            EAClient.Visible = false;
            EA_Proj = EA_Repo.GetProjectInterface();
            EA_Proj.RunHTMLReport(GUID, "c:\\test", "PNG", "default", "htm");
            //EA_Proj.RunReport(GUID, Doc_Template, FileName);
            EA_Repo.Exit();
            Console.ReadKey();
« Last Edit: June 02, 2021, 12:53:34 am by priombiswas89 »
