Author Topic: RTF-Actor Name on UCD is missing first characters.  (Read 5299 times)
Daniel Lindberg
« on: June 11, 2008, 02:38:10 am »
When i generate an RTF document from a UCD, the actor name (which has 22 characters) is missing the first 5 characters in the use-case diagram.  Is there a setting i can change to make the diagram size more correctly?  I'm using EA version 7.1.829.
Re: RTF-Actor Name on UCD is missing first charact
« Reply #1 on: June 11, 2008, 07:59:11 am »
It sounds like a bug calculating the bounding rect for the diagram.
First step would be to upgrade to the latest build.  If that doesn't fix the problem, send in a bug report directly to sparx systems using the 'Report a Bug' link at the bottom of the page.
