Author Topic: Issue with diacritic marks in Tagged Values  (Read 3586 times)
MKonrad
« on: February 10, 2010, 11:00:14 pm »
Hello All,
Maybe someone will be able to help me with one small issue with EA.
I'm using version 7.5.850 (Build 850) Unicode.
Currently I'm working with Activities in BPMN 1.1 where I have couple of unique preformatted Tagged Values to fill (Tag is set and described, but tag value is empty to be filled in later, Type is set to string). When filling empty values I can't type couple of diacritic fonts from my language (Polish). For example I can use Right Alt + A or O to write polish fonts, but I can't do that with Right Alt + E or N. Moreover when using those two last combinations some keyboards mappings (shortcuts) are activated, although they aren't configured in default keyboard accelerator map.
I can do a workaround by changing type of value field from string to memo, but I'm wondering if that's some common issue, version problem or my bad configuration of application.
Konrad
« Last Edit: February 10, 2010, 11:01:17 pm by Mkonrad »
