Author Topic: HTML report & chrome  (Read 5495 times)
Eric Bowman
« on: September 27, 2010, 07:01:30 pm »
I'm generating an HTML report 8.0.863, and it seems the report isn't viewable using Google's Chrome browser.
Is this a known issue? Is there a work-around?
Eric
alesliehughes
Re: HTML report & chrome
« Reply #1 on: October 01, 2010, 01:24:32 pm »
There is a serious issue with Chrome's JScipt engine which stops EA's generated HTML from displaying correctly.
The HTML did work with Chrome, but from the 5 series it has been broken.
See issue http://code.google.com/p/chromium/issues/detail?id=46139
So,
1.  Use a non-broken browser IE6-9, FF 3.5, Opera.
2.  Use an old verion of Chrome, pre 5.
Alistair
« Last Edit: October 01, 2010, 01:25:08 pm by alesliehughes »
« Reply #2 on: October 01, 2010, 03:28:41 pm »
Wow I never thought I'd see IE6 and "non-broken" in one sentence :o
« Reply #3 on: October 01, 2010, 05:40:53 pm »
[size=18]...[/size]
Remember, in this context "non-broken" means: able to render an EA generated HTML report.   (and nothing more)   :)
« Reply #4 on: October 04, 2010, 06:32:53 am »
OK, I voted for this issue on the Chromium site.
PS is my logic correct: EA generated javascript AND IE6 = non broken !
PPS I note that the chromium report states bug is tested against IE7 and FF3.6, has it been tested against IE8 and IE 9 (which would seem more useful) and Opera and Safari?
« Last Edit: October 04, 2010, 06:34:43 am by skiwi »
alesliehughes
« Reply #5 on: October 04, 2010, 08:30:51 am »
EA HTML output should work with IE6, if you know of a case that it doesn't please report the issue.
« Reply #6 on: October 04, 2010, 09:54:33 am »
As a Chrome user I wouldn't have a clue, IE6 should be retired by all organisations using it, its a security risk.
My question was, has EA checked against the current and next gen IE (i.e. 8 and 9), and other standards compliant browsers, eg Safari and Opera.
alesliehughes
« Reply #7 on: October 04, 2010, 10:37:53 am »
IE 6 End of Life will be when XP is no longer supported by MS.
We do check against IE 8/9, FF, Opera and Safari (to a lesser degree) on a regular basis.
« Reply #8 on: August 15, 2012, 06:57:30 am »
I have refreshed the Chrome bug report
http://code.google.com/p/chromium/issues/detail?id=142089
(add your support for this change in chromium)
« Last Edit: March 18, 2013, 06:42:34 am by skiwi »
