Author Topic: RelationShip Matrix  (Read 3755 times)
ecastil1
RelationShip Matrix
« on: February 24, 2006, 09:28:05 am »
Hi. it is possible to include the RelationShip Matrix in the generated documentation? it is possible to get a relationship diagram from the RelationShip Matrix? if possible, how is made?
Thanks a lot in advance.
Re: RelationShip Matrix
« Reply #1 on: February 24, 2006, 11:40:42 am »
AFAIK the only way for the RM is to create a separate RTF (context menu inside RM) and include this externally.
wink
  • Montjoie, que jamais ne choit!
« Reply #2 on: March 03, 2006, 01:31:34 am »
Hello everybody,
I've got the same problem. I understand that I can export the matrix to a CSV file and then import it into Excel but this requires to layout the spreadsheet manually every time I regenerate the matrix.
I would like to use the original layout of the EA matrix just as if it were a standard diagram and export it into an RTF file.
Is there any way to achieve this?
thanks in advance
cheers
Manfred
Best regards,
Manfred
« Reply #3 on: March 03, 2006, 02:08:36 am »
Only as printed PDF :-/
Or you write a RTF export for Excel :P
« Last Edit: March 03, 2006, 02:10:19 am by thomaskilian »
wink
« Reply #4 on: March 03, 2006, 03:11:05 am »
Hmm, that's what I feared... ::)
Thank's Thomas anyways.
Best regards,
Manfred
« Reply #5 on: March 03, 2006, 04:14:32 am »
A lateral solution is to have a formatted Excel spreadsheet linked to "look" at the CSV file.   8)
First open the original CSV file.
Open a new workbook, select and copy the CSV
Paste special as a link int the second workbook.
You can now format the second workbook to your heart's content and it will update as the CSV file changes.
wink
« Reply #6 on: March 06, 2006, 01:26:43 am »
Hi Paolo,
Thanks for your advice! I'll try that. However that's a bit of a problem since all my documentation is based on .doc files that include the generated RTF bits. So I will have to convert the excel sheet into doc tables. :(
have a nice day,
cheers Manfred
Best regards,
Manfred
