Author Topic: BPMN - Adding lanes to a pool  (Read 7975 times)
zigenz
« on: July 10, 2007, 05:00:22 pm »
I'm somewhat of a novice to all this modelling stuff and the use of EA, so I was wondering if someone would be so kind as to offer some guidance.
In the BPMN overview on the OMG website, it shows an instance where there exists a pool with multiple lanes.  When I add a pool to a diagram in EA, I can't seem to figure out how to add lanes to the pool.
I've looked in the help doco but it seems very light in regards to BPMN.
Any help is appreciated - thanks guys.  :)
Z
Re: BPMN - Adding lanes to a pool
« Reply #1 on: July 10, 2007, 11:59:38 pm »
You mean: Nada. Entering BPMN returns NO results in the help.
I also currently start with this and would like to see someone answering this question.
ocroquette
« Reply #2 on: July 11, 2007, 12:05:26 am »
Are you talking about this?
From the UML superstructure document
I searched how to do it too, and it doesn't seem possible in EA.
(btw, consider linking an image, it makes things much clearer ;) )
Graham_Moir
« Reply #3 on: July 11, 2007, 06:18:35 am »
I'm not sure this is going to help a lot,  but there is some help on BPMN in EA,  but you have to go to the Add-ins menu to find it.  Choose BPMN from add-ins and then "Help" appears as one of the options on its submenu.
Regarding using lanes - this is possible, although I've found it easiest - from a usability perspective - just to add the lanes individually without the pool.   Then something definitely close to the image above is achievable.
PS Changing the lanes/pool to be vertical rather than horizontal is done via the "advanced" option from the right mouse-click menu when the pool or lane is selected.
« Last Edit: July 11, 2007, 06:21:33 am by Graham_Moir »
zigenz
« Reply #4 on: July 12, 2007, 04:48:07 pm »
<image removed>
Yes, this is exactly what I was talking about.  Judging by the responses, I'm not totally stupid then.  I must say I am somewhat suprised though, given that virtually every BPMN introductory reference covers lanes and pools in this fashion.
I had a search of previous threads and it gave me some ideas, so I'll play around with them a bit more.
Thanks all.
Z
« Reply #5 on: July 12, 2007, 08:51:48 pm »
I would do this by creating a pool, and then placing multiple lanes inside.
Graham_Moir
« Reply #6 on: July 12, 2007, 11:38:13 pm »
Simon - I've tried this and while you it works, unless I've missed something, from a usability perspective it's not easy because the lanes inside the pool become difficult to select so that even getting them properly top aligned and the same width etc.. becomes problematic.
