Author Topic: excluding items from documentation  (Read 5120 times)
dschenk
« on: May 22, 2013, 09:21:40 pm »
is it possible to exclude elements from the documentation e.g. by using special stereotypes or so. its confusing if any symbol in a diagram is a separate item with an index.
kr
dieter
Stefan Bolleininger
Re: excluding items from documentation
« Reply #1 on: May 22, 2013, 09:37:33 pm »
hi,
you can store them within one packaged for example "_not_in_reports".
afterwards right-click the package and go to "Documentation->Generated-report-options" and press "Exclude from documentation."
Alternatively you can give the template the excluding information. "Project->Documentation->document template designer" and then within "Document options" in tab "Element filters".
You can define any way of filter you would like :-)
However you have to do this in EACH template you are using ::)
Regards
Stefan
dschenk
« Reply #2 on: May 22, 2013, 10:24:03 pm »
thanks a lot,
in detail i still have problems to manage it
- i want to supress the attributes of entities, so i said no elements with stereotype ERD_Attribute, but that does not help
- at second, the filter is always gone, as soon i close the windows
kr
dieter
Ian Mitchell
« Reply #3 on: May 22, 2013, 11:16:44 pm »
Have you looked at eaDocX? You can exclude items from documents without changing your EA model.
www.eaDocX.com
www.theartfulmodeller.com
Stefan Bolleininger
« Reply #4 on: May 22, 2013, 11:49:31 pm »
Which is the same attempt like the second one "with templates"
Regards
Stefan
