Author Topic: Relationship Matrix between Req's and Test Cases  (Read 4090 times)
khanabdulr
« on: June 29, 2005, 11:07:06 am »
How do I get a traceability matrix to show Requirements on one axis and Test Cases on another .....also I want to include the child element requirements and test cases too.....
Re: Relationship Matrix between Req's and Test Cas
« Reply #1 on: June 29, 2005, 03:32:23 pm »
For the external Requirements and Test cases (the ones you drag onto the diagram, and are visible in the browser).   You should be able to do it.
Use Source Type: Requirement Target Type: Test Case
Link Type: Dependency Direction Bi-Directional (to get them all)
If by child you mean internal to a classifier.  you can't AFAIK.  Convert them to external by using the button.
« Last Edit: June 29, 2005, 03:32:43 pm by PaoloFCantoni »
khanabdulr
« Reply #2 on: June 29, 2005, 04:17:24 pm »
Paulo,
I tried what you said...I have two requirements and Two Test Cases for the package...(at package level)....it shows the requirements in the matrix but it does not show the test cases....am I missing something ??
« Reply #3 on: June 29, 2005, 04:34:42 pm »
Paulo,
I didn't give any instructions as to the setting the source and destination since I don't know your circumstances.  However, you can try the following...
First ensure the Requirements and Test Cases as in the Project Viewer - that way they are eligible to appear in the Matrix.  Set your Source and Destination to the highest common point - such as the Project Root.  make sure you set the remainder of the filter as previously.
I believe there should now be no excuse for them not to appear... :D
Once you can see them, you can refine the filters (and then save the profile (via a non-intuitive process of Right-Clicking in the filter bar)
sargasso
