Author Topic: SQL query left join with nested select  (Read 10604 times)
wfsc
« on: April 22, 2015, 12:50:50 am »
i'm trying to retrieve requirements from a locally stored repository. The idea was, to retrieve the requirements hierarchy by selecting the parent object id (if any) via an existing relationship for each requirement. I tried to use the following SQL query:
select o.Object_ID, o.Name, o.Object_Type, t.Start_Object_ID as Parent_Object_ID
from t_object o
left join (select Start_Object_ID, End_Object_ID from t_connector where Stereotype = 'deriveReqt') t on o.Object_ID = t.End_Object_ID
where
      o.Object_Type = 'Requirement'
Unfortunately, it ends with an SQL error message. I believe, that there could be some restrictions about the nested left join / select construct. Is there any suggestion about such a selection?
Thank you in advance.
Wolfgang
Re: SQL query left join with nested select
« Reply #1 on: April 22, 2015, 05:10:10 am »
You're probably targeting an EAP (aka M$ Access) which has quite limited SQL capabilities (and even those are somehow screwed up). Try with a "real" RDBMS.
« Reply #2 on: April 22, 2015, 06:25:50 pm »
Wolfgang,
You better rewrite your SQL.
On something like SQL Server you can write it as
select o.Object_ID, o.Name, o.Object_Type, c.Start_Object_ID as Parent_Object_ID
from t_object o
left join t_connector c on c.End_Object_ID = o.Object_ID and c.Stereotype = 'deriveReqt'
where o.Object_Type = 'Requirement'
but on an eap you have to use
from (t_object o
left join t_connector c on c.End_Object_ID = o.Object_ID )
and (c.Stereotype = 'deriveReqt' or c.Stereotype is null)
