Author Topic: Workflow script doesn't work in EA16 (CanEditTag)  (Read 4250 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: May 25, 2022, 01:45:17 am »
A workflow script tested and working since v 13.0 to 15.2 doesn't work in EA v 16. It seems the workflow event is not triggered in v 16.
You can reproduce the issue with this simple code in a workflow script:
option explicit
public function CanEditTag( TagName )
Session.Output("TagName="&tagName)
Session.Output("MetaType=" & WorkflowContext.MetaType)
CanEditTag = true
end function
Public Function PreAllowTagUpdate(TagName, OldValue, NewValue)
PreAllowTagUpdate = ""
End Function
You can note in previous versions the event is triggered and you can see the output in the System Output window. Now, you don't see any output. The event is not triggered anymore.
