Author Topic: 64-bit compatible MDG products/addins?  (Read 11477 times)
Jakob Skepö
« on: August 09, 2023, 05:27:15 pm »
Is there any summary of which MDG products/addins that are 64-bit compatible?
Starting with Ultimate edition included MDG Products:
  • BPSim Modeling & Simulation
  • DDS
  • DOORS Link                                                   - No x64 support
  • Eclipse Integration
  • Eclipse Link
  • Microsoft Office
  • SysML
  • TOGAF
  • Visual Studio Integration
  • Visual Studio Link
  • UPDM
  • Unified Architecture Framework (UAF)
  • Zachman
Jakob
Jakob Skepö
Re: 64-bit compatible MDG products/addins?
« Reply #1 on: August 10, 2023, 04:27:53 pm »
Update... ::)
Many of the MDG add-ins have now become built-in components of the main Enterprise Architect installation, and are automatically enabled based upon the license key(s) entered.
I.e. they are no longer installed separately.
Built-in with EA:
BPSim
Zachman Framework
TOGAF
UPDM
SysML
BPMN
BABOK
Retired:
MDG Link for Visual Studio .NET (Replaced by built-in project import functionality)
MDG Link for Eclipse
MDG Integration for Eclipse
MDG Integration for Visual Studio
Jakob
Guillaume
    • www.umlchannel.com
« Reply #2 on: March 01, 2024, 02:04:50 am »
I'm reopening this thread as I reviewing the impact of upgrading to EA16.1 64 bits.
It appears that the following will no longer be available with EA16.1 64 bits (ok with the 32 bits) as the following MDGs are only available in 32 bits: Visio Import, Corba IDL
Is there a plan to integrate these in EA or release a 64 bits version ?
I also wonder if Visual Studio and Eclipse addons integration recognize EA16.1 64 bits.
Guillaume
« Last Edit: March 01, 2024, 02:54:02 am by Guillaume »
Guillaume
« Reply #3 on: March 01, 2024, 08:53:48 am »
Visio Import - Updates to this including 64 bit compatibility have been released as part of MDG Integration for Microsoft Office.
Corba IDL contains zero functionality that hasn't been available within EA itself for (many) years.
Guillaume
« Reply #4 on: March 01, 2024, 07:55:27 pm »
Hi Eve,
Thank you for the information.
I installed the latest MDG for Office 64 bits (+ Visual Studio 2010 runtime) and I can access the features with EA16.1 64 bits. Since there is (or used to be) a cost associated with this MDG, I don't understand how the Excel and Word features are available with EA Corporate. Is it now free ?
For Corba IDL, I only use the reverse engineering.
If the IDL Corba MDG has already been installed on the EA project, I can see IDL in Configure > Options > Source Code Eng. However I cannot run a reverse (Develop > Source Files > Files > Import Source Directory) as IDL is not available in the Source Type. This issue has already been identified in EA15 (issue 21057751). Is there a plan to fix it and is there a workaround to get the IDB Corba reverse to work?
For future projects, how will I be able to install the CORBA MDG within the EA Project ?
Guillaume
Guillaume
« Reply #5 on: May 24, 2024, 01:20:11 am »
I noticed on a client's PC running EA 16.1 64 bits Corporate Edition with the MDG Office installed the Import Visio Documents is disabled. It makes sense since a license or the Ultimate edition is required.
However since Visio import is supposed to be free (the 32 bits version is free), this part of the MDG Office should be available for Corporate Editions. Can you confirm if this is an issue to fix in a new build of the MDG Office Integration ?
Guillaume
« Reply #6 on: May 24, 2024, 12:04:05 pm »
There was once a free add-in that allowed import from Microsoft Visio.
Since then that has been incorporated into the MDG Integration for Microsoft Office  and further development has been done under that license, which includes 64 bit support.
Sunshine
  • Its the results that count
« Reply #7 on: May 25, 2024, 06:02:20 am »
Does the client PC have visio installed? I believe the office MDG uses visio to import visio diagrams. If not that's probably why visio import is disabled.
Happy to help
Guillaume
« Reply #8 on: June 07, 2024, 05:56:31 pm »
I installed the MDG Office 64 bits v1.4.40 (Visio 1.4.40.27237) on 2 separate computers, both with EA 16.1 Corporate and I find different results.
On one PC, all MDG features, even the Excel/Word are active
On the other PC, the Import/Export menus are disabled, including Visio despite opening an EA project.
There seem to be a bug in the MDG Office that disables for unexplained reasons the Visio > Import Visio Documents menu (Help & About are active), even when an EA project is opened.
Could Sparx team check the conditions to disable the  Import Visio Documents menu so it works fine for any Corporate EA installation and release a new build ?
Update: on the PC where the Import Visio menu was disabled, I launched EA with the admin rights and it worked. Note that the MDG Office is installed with an admin account which is different from the user account running EA.
« Last Edit: June 07, 2024, 06:37:40 pm by Guillaume »
Guillaume
Takeshi K
« Reply #9 on: June 07, 2024, 06:18:45 pm »
Hi Guillaume,
Installing the Microsoft Visual Studio 2010 Tools for Office Runtime might solve the problem. I guess you have not installed the runtime to the both machines, but it is installed when you install some other products e.g., Visual Studio. For exaple, if the active machine has Visual Studio and another does not, it could be the reason.
t-kouno
Guillaume
« Reply #10 on: June 07, 2024, 06:53:47 pm »
Hi Takeshi,
Thank you for your reply.
The VS2010 tool runtime has been installed on both installations.
It works if I run EA with the admin rights so there seem to be an issue with user permissions somewhere. This is strange because I have another custom addin that works fine.
Update: I reported a bug
« Last Edit: June 10, 2024, 03:44:23 pm by Guillaume »
Guillaume
Guillaume
« Reply #11 on: June 17, 2024, 04:24:23 pm »
Update: I also noticed that when I change the EA license from Corporate to Ultimate, the Import Visio menu is enabled. This issue seems to be linked with MDG control of the installed license, introduced since the free Visio add-in has been included in the MDG Office (tested with the 64 bits version on EA16).
Guillaume
« Reply #12 on: June 18, 2024, 08:43:42 am »
It sounds like you're still expecting it to be available without the purchase of an appropriate license.
MDG Link for Visio as a free download has ceased development. It was last updated in 2017. It has been replaced by a component of MDG Integration for Microsoft Office which requires a license.
It's not that the 32 bit version is free, it's that we still allow you to download a very old version. All of the improvements in the last 7 years including 64 bit support are only available through a licensed copy of MDG Integration for Microsoft Office.
« Last Edit: June 18, 2024, 03:20:36 pm by Eve »
Guillaume
« Reply #13 on: June 18, 2024, 05:31:34 pm »
Hi Eve,
Thank you for the clarification. I misunderstood and somehow expected that the Visio Import would remain available for EA Corporate users moving to 16.1 / 64 bits.
Guillaume
Roche Pso
« Reply #14 on: July 25, 2024, 01:02:38 am »
So, having read through this thread, am I correct that for the 64bit version of EA 16.1, the only additional files needed to get everything currently available installed are:
DoDAF-MODAF.exe
EADDS.exe
and pick one of:
mdgoffice_x64.msi
mdgoffice_x86.msi
