Author Topic: Crash on Documentation Generation  (Read 3545 times)
nshafer
« on: March 24, 2010, 12:43:02 am »
I recently upgraded from 7.1 to 7.5.  I completed an uninstall prior to the installation.  I now can not generate HTML documentation without having a crash occur.  Looking at the event logs i'm seeing the following fault:
'Faulting application ea.exe, version 7.5.0.844, faulting module drawex.dll, version 0.0.0.0, fault address 0x00009e66.'
Has anyone run into this fault before and if so did you find a solution?
bash
Re: Crash on Documentation Generation
« Reply #1 on: April 01, 2010, 04:32:57 am »
Try to modify your Diagram settings.  Go to Tools|Options then under Diagram select Appearance.  Try to change the Renderer and then run the report again.
« Reply #2 on: April 01, 2010, 09:21:27 am »
You can certainly change the renderer, but I believe the problem was fixed, possibly in build 845.
